- added option to disable service type indicators in front of servicenames (options panel GUI)
- added new cleanup function for local picon directory (removes all picons not found in any user bouquet)
Note: the other option removes only picons not found in both lamedb AND user bouquets
- added High-DPI support / scaling natively without losing sharpness
- added scaling factors 100%, 125%, 150% and auto (depends on system setting)
Note: this will override the font size selection which is now only used on 100% factor
- added 64-bit build of dreamboxEDIT
Note: use VLC 32-bit for standard and VLC 64-bit for x64 version of dreamboxEDIT
- improved dreamboxEDIT installer: new accessibility options (high contrast mode, scaling mode)
- improved automatic VLC path detection for use with 32-bit/64-bit dreamboxEDIT/VLC at the same time
- improved manually set VLC path is now separately saved for 32-bit/64-bit VLC
- fixed writing hidden/numbered markers (some invalid descriptions were written before)
