flie писал(а): 16 июл 2019, 00:18 I don't know how to make transponders appears in transponder list in oscilloscope-mode ?
Очень просто - следуйте по цифрам:
А это пример сканирования в режиме высокого разрешения:
Число найденных транспондеров здесь больше :good:
flie
Ресивер: TBS5927
Благодарил (а): 246 раз
An other simple test @15°W 12500-12750H; just to see the difference between results of "Number of IQ-points" :good:
it is obvious that ;more time we use (bigger of "Number of IQ-points" )...the best quality of IQ-spectra we get Изображение
unfortunately I can't get good results this time ; some times a part of Spectra (12500 to 12515H) is missing! and a error message some time appears :-( ! may be it is the same error-message appeared before to PEON Изображение,I hope it definitely solved in IQmonitor's last version: 2.2.0.1 & 2.2.0.2 :Bravo:
-some times there is problem to IQBlscan if transponders are too near from each other like situation here (12701,12706,12710H)12710H is missing ,I can't see it clearly with H.R.Spectra ? Изображение
but this problem can be solved with classic-Blscan (step=1,band=1) :good:
any way It is an honor for me to discover the capabilities of IQmonitor in order to make it work best Изображение
Added in 1 hour 4 minutes 54 seconds:
I can't deny that there is some thing interesting in @15°W 12500-12750HV !!!;these Unlocked transponders with Crasyscan and TBS5927 ! could be DVB-S2X Изображение
-some of theme are reported as DVB-S2X in Flysat by satesco :good:
and I can see them with the H.R.Spectra :cool: may be I have low signal here :oops: .
-unfortunately TBS5521 can't see lot of them 89?! may be because they are ACM , also BlindScan2 with Crazyscan & TBS5521 gives every time a different result !! :facepalm:
Added in 8 minutes 47 seconds:
can some one please check this one with TBS-X ; 12633V ?
Unknown with TBS5927 ...
But with TBS5521 there are 3 different results !!!:
-12633_V_DVB-S2-QPSK-34-TRANSPORT-MIS0
-12633_V_DVB-S2-16APSK-78-PACKETIZED MIS0
-12633_V_DVB-S2-64APSK-L-23-SINGLE !!! TBS5521 can't support 64APSK :shock:
I tried feed-reports with IQmonitor even with N=5500X20 ! I can get only one result : 12633_V_is :DVB-S2-QPSK-34 ?! Изображение
Added in 1 hour 51 minutes 42 seconds:
yes they are DVB-S2X with this excellent result of H.R.Spectra Изображение
I can confirm from here : :Yahoo!:
with IQmonitor H.R.Spectra TBS5521 can see 64APSK signal Изображение
very hard to get this feed-report :-D
Поздравляю с отличным результатом! :Bravo:
Я впервые вижу feedreport с модуляцией 64APSK-L и rolloff=0.05 :Yahoo!:
Обратите внимание, что IQmonitor правильно определил полосу частот, которую занимает транспондер. :good:
Это очень хорошо видно на спектре высокого разрешения, а в CrazyScan, видимо, при расчётах был использован rolloff=0.35. :no:
Думаю, что Crazycat легко исправит эту ошибку в его программе :friends:
Благодарил (а): 36 раз
да будто бы и CS рапортует 0.05
flie
Ресивер: TBS5927
strannik писал(а): 20 июл 2019, 15:37 Поздравляю с отличным результатом! :Bravo:
yes the result are better if I use H.R.Spectra :good: , I tray also BLScan2 & BLScan1 with both program Crazyscan and Ebspro; always there are some transponders are missing ! so scan with H.R.Spectra for DVB-S2X with TBS5521 is better Изображение
*It's a really amazing result with IQmonitor made by a non-powerful card like TBS5521 ... :Bravo:
-unfortunately TBS5521 can't analyse this DVB-S2X 32/64APSK ....it can support only DVB-S2X 16APSK ! :wall:
-also feed-report hardly obtained for this DVB-S2X 32/64APSK with TBS5521 ...it is more than it's limit Изображение
strannik писал(а): 20 июл 2019, 15:37 Это очень хорошо видно на спектре высокого разрешения, а в CrazyScan, видимо, при расчётах был использован rolloff=0.35. :no:
yes that rolloff = 0.35 was obtained with TBS5927 that is not able to receive S2X signals Изображение ....I think the problem is what Satesco said before Изображение :https://www.satellitescommunity.de/thre ... =1773&sid=
-there is a simultaneous transmission of the streams in dvbs2 and S2X on the same transponder Изображение like Genetic-stream before(many modulation at the same time) !
but this time it is much worse;many modulation and standard transmission (s2 & s2x)at the same time Изображение...Unless they are still testing :unknown:
I repeat the scan to day ;this 12720V was 16APSK now it is 32APSK_L :facepalm:
Последний раз редактировалось flie 21 июл 2019, 22:21, всего редактировалось 1 раз.
CrazyCat писал(а): 20 июл 2019, 23:49 да будто бы и CS рапортует 0.05
Вы не правильно меня поняли.
RollOff = 0.05 Это показывают обе программы.
Но CW = SR x (1+ RollOff).
IQmonitor показывает ширину полосы транспондера 27МГц = 25.72 х 1.05, и это подтверждается высокоразрешнным спектром.
CS показывает полосу 34.722МГц, что соответствует RollOff = 34.722/25.720 - 1 = 0.35. В этом и заключается ошибка в CS :pardon:
Отправлено спустя 23 минуты 19 секунд:
flie,
Вы путаете распознавание вида модуляции сигнала (чем занимается программа IQmonitor путём трансформации I/Q констелляций из DVB-S2X в масштаб созвездий стандарта DVB-S2) с демодуляцией этого сигнала.
Ваша карта не может (по вашим словам) демодулировать сигнал 64APSK_L, но она может получать поток I/Q отсчётов, из которого IQmonitor извлекает информацию о параметрах сигнала, в том числе и виде модуляции.
действительно была бага в стримридере с вычислением ширины полосы.
залил тестовый 1.2.4.83
http://crazycat69.narod.ru/sattelite/St ... Ex-BDA.rar
Здесь мой прием с 15 ° на запад.
Макетное сканирование IQMonitor нашло (с потоковым ридером 1.2.4.83) транспондер с «только» 16APSK при 12672В
Благодарил (а): 486 раз
С новым потоковым ридером BDA и TBS 6983
Это передача. Я мог слышать английский тон, но картина не правильная. Сигнал варьируется от 0 до 11,8 дБ.
С IQ Monitor он не работает с плеером VLC, ничего не слышно
