V 3.7.1
- Improved Rosscrypt1's key detection.
- Added Rosscrypt1 (CA-ID=0xA101) support:
40.0E 3675 R 33483
53.0E 3675 R 33483
80.1E 10981 V 33483
также, если в версии 3.6.0 добавили это то и в последней будет работать
- Added Compel support, 4.8E 12379 H (ATG EU BSS & K75 International).
You can define these types of channels in `PowerVuEmu.ini` file, under the `others` section. Its format is `pmt:sid;`.
DVB Emulator Cam's
- milan58
- Антенна(ы): Triax 110
DVB Emulator Cam's
Кому нравится перевод на русский язык.Kроме .dll имеет .mod для DVBDream
DVB Emulator Cam's
This is just for testing. It works for nearly 4 minutes and then stops. I think they use another frequency to update the keys.
This is how BeOutQ Works:
1- Update your TSReader to its latest version (at least V2.8.53a). This version supports H.265 Videos.
2- Update your VLC player to its latest version too (at least version 3.x).
3- Tune to 12341H transponder.
4- Select `File->Load manual channels` menu option and then open the `1-BeoutQ-12340-H.tmc` file.
5- Tune to its first channel to find the keys (see the new TOT tab for more details).
6- Now tune to 11919H transponder.
7- Select `File->Load manual channels` menu option and then open the `2-BeoutQ-11919-H.tmc` file.
8- Tune to one its 10 channels to view it.
Tip: To play x265 videos with VLC smoothly (with less discontinuity errors/glitches), you should increase the `network caching` value:
VLC -> Tools menu -> Preferences -> Show settings -> All -> Input/Codecs -> Advanced -> Network caching
